Sump gasket
(In Topic #144449)
Sump gasket
I have an issue with my sump / gasket, mainly that it is leaking!
fitted a new sump and one of the windage type baffle things last year, since then i have oil all over the underside of the car, strutbrace and any other surface for that matter.
Think the issue maybe the gaskets on the baffle plate.
To cut to the chase, I will be swopping the lot out for a proper baffled sump, and would like to know what the best gasket would be, the newer rubber ones or something more old school.
advice would be cool, as I really don't need oil everywhere!
Thnks Chris
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
not sure wht to do with the new sum, prob be a patern one.
the reason i ask is ive seen a few people with the same issue due to poor quality sump, it can also happen if the sump is bent out of shape. the trouble is the gasket sealing surface its not flat its ridged if that makes sense, and so is the sump surface.
i heard diesel sumps were sometimes flat but not sure.
anyhow, I think the new sump is reasonable quality.
I was not sure if the rubber type gaskets are worth looking at?
maybe a bit of gasket seal may help?
I will keep clear of the gasket sealer.
