Alpine White G60
G60RGE said
we all make mistakes…
Hi,
What is the main reason why you are going to back heater and fan?
Last edit: by .wide
Your Moderator Manager
Sent from my Smartphone
.wide said
Hi,
because its very cold and it was a stupid modification
and blasted and weld through primed ready to be welded back in
any recommendations?
managed to source a heater box too
Last edit: by G60RGE
It clears the alternator pully by 1mm
I still have a whistle sound on overrun i can't for the life of me find out what it is? any g60 experts on here?
looking a bit oily, i really need to get this charger checked out
finally got the seat centers trimmed, very happy with the results, it looks like a gti again!
Alpine White G60
Arthur83 said
Did you have to modify the air box at all? Mine looks like there isn’t any chance of squeezing it in!
yup, a lot
i had to cut a lot off the bottom, im going to plastic weld it closed with one hole as original and make a bracket in the future
Alpine White G60
G60RGE said
yup, a lot
Do you have any pictures by any chance?
I guess you had to chop the bottle bracket as well?
The dash has been test fitted and lines up perfectly to the heater box. Ive also ground back behind where the matrix pipes go through the bulkhead and can see where the old hole was but for some reason it seems bit off so not sure if i should drill that just yet…
i have seen the matrix hoses are angled so maybe that's me just worrying
Once it's back in you will be a happy chap. Are you getting the engine out for the rain tray?
Just be careful about its vertical position where the seal sits on the bonnet. Tack it up and trial fit the bonnet.
Keep the good work up
Rich. said
Looking good, a bit daunting isn't it.
I've been putting it off because I was sad i had to ruin all that hard work to get it all smoothed. I also knew once i start its going to become a mammoth task. il bear the bonnet test fit in mind thanks for the heads up
thinking the engine needs to come out but im also thinking about bonding it in as another option that way i can just put it together without taking the engine out or taking it to get painted. im also not too fussed on the finish right now as im putting it all back to a standard where it can be used and not for show.. Actually, i have no plan. im just going along with it
still need to run all the brake lines and put the servo back in
The three holes for the servo bracket were easy to locate and drill through as the strengthening bracket on the inside was still there
Next i ground down behind the bulkhead to reveal my lovely welding where the matrix hose hole was
hole drilled out
quick lick of paint
all fitted up
and the inside, excuse the mess, looking forward to carpet final fit making up some under trays and a bloody good valet
As you can see its progressing nicely, i need to start thinking about brake lines, i remember binning the rear brake compensator which im kicking myself for now!
can anyone recommend a decent brake pipe flaring tool and brake pipe kit?
notice i had the bodyshop weld a strengthening plate here as the bolts were welded to the bulkhead and the support bracket in the bay was removed
well the bolts they welded in weren't quite in the right place but my guide hole showed me exactly where i needed to be, i chopped those bolts off anyway as the standard pedal box has bolts going through the bulkhead
All done
Crazyquiffs Brake Pedal box for sale
will also weld in the support bracket once i take it all off for power coating.
Very happy with this afternoons work, I've been putting this off for ages thinking it would have been a nightmare but getting stuck in has proved me wrong.
next step, brake lines
you can tell from pic 2 this car hasn't been driven for a while from all the cobwebs and rusty discs . It really needs a good going over/stripdown re-paint under those arches
parts needed
residual pressure valves x2
brake hose grommets x2
brake regulator complete with spring and hardware
brake switches x 2
shame i can't get the brake linkage and pedal box off to be powder coated right now, il get as much as i can done until i source the bit i need
brake servo mod, I've lost count how many times and mk1's ive done this to over the years
Finally managed to source a rear brake regulator but it was in a bit of a state
Little refurb, i actually found the pully in my box of bits from 10 years ago
new grommets for the brake hoses
All pipework done and regulator on, yes i paid for someone to paint flakey undersea on as part of a restoration….
Re done the master cylinder pipework as it looked too messy
Was going to fill up the system but one of the front caliper bleed screws looks mangled so will leave it for tomorrow maybe
