Project JD
(In Topic #141088)
Project JD
what do you think
then found some more rust!!
and a hole in the floor
started to strip it out
thats it for today
then i started on a S1 dash which needed alot of work
still got a lot to do on it i'm thinking of covering it in carbon fibre
took out the brake system and gear box linkage
then the rear windows found some rust around the seals it looks like surface rust so not that bad i think?
does anyone know how to remove the tailgate/do i need a special tool for it??
the tailgate is out now
now thinking can i save the tailgate from the bin
got the rear axle off then started to cut out the fuel filler repair panel looks ok will is how good it is once i've welded it in
was thinking should i repair rear tub where it meets the fuel filler panel ??
then started cutting out the rear left hand arch and matching it up to the repair panel
then started striping out the sound deafening got half way through it and ran out of juice
thats it for today
repairs to both doors and wing
butleraw said
You're making good progress there. Did you repair the tub behind the fuel filler in the end?
haven't started on the car as yet hoping for better weather LOL
got my new roof started prepping it
just a little update started building my rear disc conversion using polo 6n2 parts its looking good
not finish yet just waiting on brake lines and disc an pads
also started work on the tailgate striping it down to bare metal then a bit of filler over the part were i removed the lock and welded it up
should be spraying Epoxy 421 on it soon
started removing the under seal to find more rust i'll let the photo's do the talking
started to weld in some new metal but then ran out of MIG gas and ran out of petrol of the Generator long ting LOL
Last edit: by marlonjd
Design Manager
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
