mk1 rivage S3 conversion
(In Topic #113564)
there is a conversion guide to the left of the page.
failing that pop up a post in the "modification" section.
and get some pics up too!!!!!!
Thanks Paul
whatalotafun said
welcome mate,
There have been some problems getting the 20vT tech guide onto the website so there's a few others you can try in the meantime:
http://www.fastgolf.or…ontent&pa=showpage&pid=13
http://www.qpeng.com/conversion_guide.html
AFAIK for the engine mount, you use the Mk1 Golf one on the right (driver's side) and the transmission mounts - if you stick with the 020 trans then use the big block tranny mounts, if you use the 02A/J trans then use or fabricate your own conversion mounts. An eBay search should find you some. Unsure if the S3 has a 6 speed manual box, if it does then I've heard there's packaging issues fitting it into the Mk1.
There will be loads of questions though so try a search (lots of helpful stuff already) or ask away in the modified section!!
Good luck!
