VW mk1 loose strut?
(In Topic #217467)
https://youtu.be/aod5grdwsEY
I have seen that on a mount that had the inner strut bushing that was taller than the flat of the mounting cup, so while the strut tightened, it wasn't fully seated on the mount as it was up a tad.
Duct Tape really is for the win, when combined with cable ties the world is your oyster!
( I am not sponsored by nor advertising duct tape or cable ties!)
Part No10 in this picture.
https://volkswagen.7zap.com/en/rdw/golf+cabriolet/goc/1988-44/4/411-102000/
It wasn't fun, but when the pressed stud spun in the hole as I as installing it, I had to worm my Wire-Welder up the inside of the strut to the stud. I had my son hold the nutted stud up, and tack welded it in place which allowed me to remove the strut assembly, then properly tack weld both pressed studs.
About a week and a half before I replaced them I filled the bottom gap with 3m Window Weld… made the ride a tad higher, and a little stiffer, but if it lasts a tad longer I am fine with that.
Rule of thumb is if the gap is bigger than your thumb then it's time for a change.
Get Febi strut mounts and avoid Meyle as the Meyle ones I tired lasted 6 months and 4 months of that the car was just sat in the garage!
If fitting new strut mounts you may need to undo the 2 bolts which hold the strut on and this is upset the camber and you will need to reset this which involves either a garage visit with the right kit and about £70 of your money…
You can do it in your garage with a gauge and support the car on the wish bone as the car needs to be sat on the floor and level to get the reading then with the wheel removed you can adjust the camber.
I've just just set mine and tried a different method. Make sure all the tyre pressures are correct.
I've got an adjustable gauge (set the gauge to 0 using a level) and with the car on level ground I get a reading by placing a level on the edge of the wheel and the camber gauge say "2 degrees" then jack up the car, remove the wheel and place the camber gauge on the hub then adjust the camber gauge to read "2 degrees " then adjust the camber to 1 degree" refit wheel and lower the car, take it for a quick drive then check the setting once back on level ground.
https://www.ebay.co.uk/itm/Universal-Magnetic-Alignment-Gauge-Castor-Camber-Scale-Wheel-Tool-Vehicle-Set/262132295571?epid=11005359202&hash=item3d084d6793:g:-HYAAOSwLoxa2VJd
The play in the strut is the metal ring/spacer (part 9) is a crush ring/spacer but I've never been able to crush them when doing up the nut so I file/grind them down a little so not much play and pack them with grease seems to help.
Spacers look like this when removed.
https://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIO-SCIROCCO-CADDY-STRUT-SHOCK-TOP-MOUNT-SPACER-SLEEVE-x-2-C02/221277166691?epid=1627179830&hash=item3385259c63:g:-3cAAMXQtRxSJKQI
With the car on the floor you can undo the nut and with a couple of screw drives or pliers remove the metal spacer and file/grind some of it, then replace it and do up the nut, jack the car up and place something underneath the wheel (I use the trolly jack bar) and lift it up a couple of times and listen look for the play you have in your YouTube clip, if still there grind a little bit more off and try again, once it near and you are Happy pack the mount with grease and refit the metal spacer.
Don't go mad grinding down the spacer or you will close the gap to much and it will pinch the strut mount and it will bind on the mount when turning the steering.
Make sure you don't lift the car with the nut off or the spring etc will all fall off.
I guess you have the Allen key to hold the shock and angled ring spanner or open sided socket to undo the nut?
You will need spring compressors for changing the strut mounts.
I think that's everything…..
Last edit: by mark1gls
I seem to remember when I changed the front shocks on the MK2 I had as a daily driver the upper mount relies on the weight of the car to remain in place and flops about when the car is jacked up enough to get the front wheel off the ground? There's just a retaining plate to stop the strut dropping into the wheel well?
Break the torque of the axle nut with the car down on the ground and loosen slightly, I SAID SLIGHTLY
Remove the Brake Carrier with caliper and brakes, remove the rotor as well, that is 2 17mm bolts and suspend it via a Wire as you don't want the weight of the thing hanging by the hose. I usually use the hose bracket that is welded to the inner fender.
Remove the pinch bolt / nut from the lower control arm to ball joint.
Remove the Tie rod from the spindle.
Pry the lower control arm off the strut tube.
Remove the 2 nuts that hold the strut mount to the strut tower.
Remove the axle nut, and push the axle out of the spindle.
Remove the strut as an assembly and you don't mess up any alignment.
If you want to break the two camber bolts first.
Buy a large magnetic angle gauge, and attach that to your rotor, make sure that you mark the position of the strut tube to the spindle first.
Attach the Angle gauge to the rotor, and wright down that angle that it is sitting at in sharpie on the rotor.
new improved easier to read.
You can then reset your camber and save a trip to the alignment shop.
