150PD ARL 02A engine clutch gearbox questions
(In Topic #211306)
I've got a Mk1 Caddy which is currently running(sort of) an AAZ and 02O box, fifth gear died and I was going to fit a new O2A box I have, but I've been offered a complete Seat Leon 150PD(the entire car) for very cheap, my question is this….
The Leon has an 02M box and has just been fitted with a new clutch and DMF, will the 02A box work with the DMF or will I need to change this for a different item?
I ideally want the 02A because I have already bought all the mounts, rod linkage and clutch cable kit.
Any help would be appreciated
Richard
the same flywheel can be found on all corrado manual 4 cylinder cars, plus most passat b3/4 manual 4 cylinder (soemr poverty spec have smaller flywheel, it needs to be 228mm) plus the mk3 golf 16v and tdi
rubjonny said
no it wont, the 02m stuff is all different. all you need for 02a is g60 type flywheel and a vr6 clutch kit (beefiest oem option)
Thanks Jonny, looks like I'll still have to buy a clutch and flywheel setup! ha.
