Top of clutch pedal light after clutch change
(In Topic #208369)
New cable needed?
Just got my 1.5 GL back after its had a new Sachs clutch kit fitted and new transmission fluid.
It feels great: I actually have a biting point at the middle of the pedal now and it feels like a modern car, nice and light and no more slipping!!
However the top part of the pedal is now very loose/waggly until you depress it to the biting point.
The cable itself has now got space between the metal shroud and the plastic circular top of the cable when it didn't before, so I'm guessing it needs adjusting?
Or could it be that the cable is stretched/tired and that I just wouldn't have picked up on this before because the bite was right up the top and the clutch was knackered?
Grateful for any help!
AntF
There should 10mm of play at the top of the pedal movement so when you adjust the cable make sure you adjust it properly.
If you don't have a clutch repair plate on the bulk head fit one as well even if there is no sighs of cracking as it's such a weak point and fitting a plate will help strength the bulk head, the plates are stick on so clean around the area and push it on, I found a little grease around the rubber grommet of the clutch cable helps it slip into place when refitting as it can be a little tricky with a plate fitted.
Plate looks like this, 1st one I found but GSF and other places also sell them.
http://www.ebay.co.uk/itm/VW-GOLF-MK-1-GTI-BULKHEAD-REPAIR-PLATE-SCIROCCO-/272450886331?hash=item3f6f569abb:m:mDc5R0ft1sV4OxxE5dQXBTg
as above though, deffo buy a new cable first
I've adjusted it as best I can to get the 10mm of play, but I've noticed that the bottom rubbers are all shot too and I'm missing the rubber washer, so I'll get a new cable and replace these parts when I get paid. And get a bulkhead plate!
Much appreciated.
http://www.classic-vw.co.uk/clutch-cable-rubber-guide--washer-171721307--171721308-4171-p.asp
To be honest I can't really see the point of the rubber washer so that is why I don't have one on mine.
http://www.classic-vw.co.uk/clutch-cable-rubber-washer-171731307-4174-p.asp
I would just buy this part and save some cash.
http://www.classic-vw.co.uk/clutch-cable-rubber-guide-171721308-4173-p.asp
There is other places selling them and some on ebay as I see they are out of stock at classic VW.
