Rear pads too thick?!
(In Topic #217554)
Got a rear disc conversion on my mk1, and am replacing the discs and pads.
I ordered these discs: https://www.vwheritage.com/357615601-rear-brake-disc-226mm-with-4x100-stud-pattern-vw-spare
I have the standard conversion calliper / carriers.
I took off the old pads and ordered the exact same ones (PAGID T5075): Pagid T5075 Brake Pad Set, Disc Brake : Amazon.co.uk: Automotive
I have re-fit and the pads are in the carriers. pistons have been wound back as far as they will go…but the calipers will not fit!! The pads are just too thick - I reckon about 2mm.
Can anyone tell me whether the pads that I ordered were the wrong ones? And if so which ones to buy?
Thanks!
I looked at the rotors and they are solid.
I can't tell about the pads.
The pads I bought are 87x53x17.2mm
eBay
Looking at other pads, I can see they are 87x53x15mm!!
http://www.ebcbrakes-webshop.co.uk/view.aspx?type=aut&vrm=&pid=106641
So this 2mm difference per pad would definitely make up the difference!!
Anything else I should know before I stump up for some new pads again? lol
