No speedo drive in gearbox
(In Topic #222758)
There is the gearbox number but confuse in which drive I need and where to purchess one in uk
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
http://www.4crawler.com/Diesel/VW_020_transmission.shtml#Speedometer
On the drive
Myvalver 89 GTi Grey mk2 16v
1983 GTI-Black
Red 15 tooth.
171.957.821.B
https://www.vwheritage.com/171957821b-speedometer-drive-gear-z15-for-manual-gearbox-red-vw-spare
Don't forget the clip. The ETKA isn't working today….so I can't give you the part number.
Briano1234 said
from Transmission Ratios
Red 15 tooth.
171.957.821.B
Clip?? Sorry I don't have clip as the drive itself is missing
1983 GTI-Black
There is a Small "C-Clip" that holds the gear to the cable. in removing the cable I have heard of the clip failing and the gear falls into the tranny…..
errr… have to agree that a 'missing' drive is prob in the gearbox from someone yanking the cable. On my GTI the deep pressed metal 'paint tin lid' was very tight and I had to carefully lever it with 1st a razor blade and then small screw drivers. Pulling the cable would have just stripped the clip and drive off the cable leaving the pressed metal cover fixed in the gearbox and the bits dropping into the bowels of the gearboxBriano1234 said
I hope that the gear didn't fall into the tranny as you were removing the cable. I have heard of folks that kept filling their tranny's and the gear under a gentle rocking floats near the hole…..
