Drilled rear discs?
(In Topic #217444)
So I'm replacing the discs and pads on the golf. It came with a rear disc conversion already (226mm x 10mm) and uprated front discs (283mm x 20mm).
The rears I have are drilled, and I can't find online anywhere any rear discs which are drilled. Is there any point? Should I just go for the solid ones?
The golf has an R32 lump in it, so I want to make sure the brakes / pads setup is strong. Any advice on which discs and pads I should get for strong brake performance?
Cheers!
The Vented fronts and solid rears are more than sufficient to Stop your car. IMHO. The Drilled and Slotted are Showy, High Priced and Don't really add to the Braking of the car they are showy, and more costly and I have seen most of them made from "Chinese" Steel.
Look for American, German, Canadian made rotors and such Higher Grade of steel, and usually 2 times the cost of the low end.
For Pads I have been using Hawk Ceramic pads for years on my Cabriolets, I got a good deal on 6 sets @ 5 bucks each because of discontinuing the product line at a vendor.
I have been using Ceramic pads of different types (makers for years). I had a heat fade issue on a Van I drove, and the Ceramic pads took care of that, they are rotor friendly, and Dustless as compared to Semi-metallic, and or organic pads.
I'm finding it hard to find 4x100 283mmx20mm fronts though…is there an easier / more standard size to find?
Also, below is a picture of the pads currently on the car. Bottom one is off the rears and the top 2 are off the fronts. Note how the top two are different shapes but were on the same calliper…is that normal?
I've not done any brake work before, hence my very beginner questions! Appreciate the help!
https://www.vwheritage.com/wc615kbd404d-black-diamond-brake-discs-280x22mm-drilled-pair-vw-spare
There another manufacturer that has 4x100 with 283x20mm as standard?
https://www.ebay.co.uk/itm/FRONT-DRILLED-GROOVED-280mm-BRAKE-DISCS-FOR-VW-GOLF-MK2-PASSAT-GTI-G60-RALLYE/232706418219?fits=Car+Make%3ASeat%7CModel%3ACordoba&hash=item362e62262b:g:51sAAOSw-b9axPY0
These discs seem to be the right size…apart from the overall depth. Says that the overall depth is 39.2mm, but measuring my discs they seem to be 50mm overall depth.
Thoughts or alternatives?
(also I'll get a picture of the front callipers soon so I can try and figure out which pads to get)
Who knew brakes were complicated?!
Also a photo of the different sized brake pads in the front carrier.
Brakes: https://www.buycarparts.co.uk/brembo/1657055
epytec adapters: https://www.bolt-action.nl/product/mk1-280mm-g60-brake-adapter-kit/
Pads: https://www.mtecbrakes.com/brake-discs/volkswagen/corrado-89-96/corrado-1-8-g60-07-89-12-92/front-brake-pads/dp2841.html?gclid=EAIaIQobChMIsNfE1fPs2gIVTbTtCh2JqQzTEAQYASABEgIGOfD_BwE
BUT, I am finding it bloody confusing finding the right calipers and carriers… I can't find the right ones and am pulling my hair out. Seems I can get corrado or mk2 g60, but maybe also mk3 gti 16v… But I can't find carriers at all anywhere!!
Couldn't help point me in the right direction for the calipers and carriers? (assuming the discs, pads and adapters above are correct)
