Brake adapters
(In Topic #216085)
Brake adapters
Brake adapters
Brake adapters
I have some slightly bad news on the mk2 caliper front, you've 1 256mm caliper and 1 280mm (with dimples on outside)
Brake adapters
for the new ones, the one with the extra dimples machined into the outside is a 280mm version, and the other is the 256, they are the same except the 280 caliper is wider to fit over the thicker 280mm disc/pad combo. If they both came from the same seller maybe get in touch and see about a return/replacement
Brake adapters
Brake adapters
someone will buy it worst case no problem so its not the end of the world
the audi gear will bolt right on, if he has 2 sets then quids in you'll make a fair wedge of cash sellign the other set
