5 speed gear lever adjustment
(In Topic #211796)
Cant get 5th
I cant move my gear lever enough to engage 5th gear. The part of the gear lever under the car is touching and not letting the gear lever move over enough to engage 5th. Any ideas? Once photobucket decides to work i'll upload a picture of where the gear lever is touching. If I disconnect the linkage I can engage 5th gear by hand from the gearbox in the engine bay.
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
Also how can I check that I have the correct gear lever / linkage? as my car used to be a 1.1 but was bought with a 1.5 engine and 5 speed box in although 5th gear has never worked from the gear lever so I'm just wondering is there another issue other than just the adjustment
Not sure if the cabin lever is the same or different. The big block 4 and 5 speed mechs are different. There may also be an issue if the relocated engine mount is not in the right place.
Finally are you sure it's a 5 speed box, not a 4 (or a 3+E)?. The 5's have a round green metal 'lid' on the end of the box when looking under the wheel arch.
