Where to get a lower suspension brace for an auto.
(In Topic #223515)
I seem to remember someone had posted a link to lower suspension braces a while back. I cannot find as I'm a technomuppet and get inundated with post about the wrong stuff.
I want one for my 92 Clipper cabriolet automatic. I might as well fit one whilst I cannot drive it, does anyone recommend a cheap reliable supplier
OKaaay, Lets try again a different way. I have found this, has anyone used one?
https://www.ebay.co.uk/itm/TA-TECHNIX-FRONT-LOWER-STRUT-BRACE-BAR-STRUTBAR-RED-VW-GOLF-MK1-CONVERTIBLE/233453281058?hash=item365ae65f22:g:RjAAAOSwQItT-1Kh
That may work, but to install it you will have to loosen your engine mounts and jack the auto up, make sure that you have a block of wood under the pan, or that you have an engine hanger as there isn't but a inch of clearance between the pan and the control arm bolt on an auto.
Many thanks Briano,
So, with that little clearance there is a good chance it will ring like a church bell after a wedding. That's why I wondered if anyone with an auto could recommend a lower strut brace.
I have a Weber conversion so I don't think most top braces will fit either.
It's just that whilst the car and I are under house arrest it would have been something to be getting on with.
There just isn't a whole lof of clearance on a Auto that the manual has…. and it is really really close quarters
I thunked that years ago some one made a upper brace or had it made for a Carbed engine….. Most of the carbed cars I see over on this side of the pond are running the 16V and the carbs on the front side of the engine.
It was a rube goldberg looking thing that had gussets on the corners….
