K-jetronic problem
(In Topic #223674)
I have a big problem with my Golf 1 convertible 1800cc with mechanical k-jetronic
Will start from the beginning.
I had started restoring her a few years ago but was unable to continue due to circumstances. Result she has stood still for a few years. Now I have finally been able to get back to it and try to start her. She started but came to a halt after a few seconds and didn't want to start after that. The starter also had trouble getting the engine around. The cylinders, inlet and oil were full of petrol. After looking no further I thought of piston rings broken after standing still for so long so I searched and put another engine but still have the same problem
after looking further and testing my injectors I saw that as soon as the petrol pump is running all started spraying without me lifting the air valve so I checked the distributor and it was completely blocked. Then bought overhaul kit after everything was nicely cleaned and reassembled i have still the same problem, then i tried other injectors but no difference. As soon as i on the petrol pump all the injectors give petrol I no longer know what to do hope that maybe there is someone here who could help me. Pls.
Kind regards
https://www.facebook.com/joeyribbens1981 seems a well nice fella
some info on these pages and links..
Fuel Injection - The Mk1 Golf Owners Club
dont worry plenty of advice and ideas will come along, to me sounds great that you have fuel reaching injectors so really you need spark and then should start. if no fuel there then id be more concerned. did you have part number for cis unit maybe you can swap that for a working 1 if you find that's the issue. But i suspect its more of spark issue…Timing, or ignition coil or ignition module that's my guess since pumps seem fine.
On the drive
Myvalver 89 GTi Grey mk2 16v
The moment i put my pomp again he stops. I am getting to much fuel in the engine
All help is welcome and i thank you already
Bosch K-Jetronic Fuel Distributor Seal Replacement - YouTube
Playing with it all now
HERES THE PHOTO: Caveat::: no need to comment on the fire risk….
Got the rebuild kit complete on the metering head and loctited the seal and it works good, ballanced the injectors and it all works as it should on AFM lift. Back in car now but still wont start but least I know that parts are good. Now to run through WUR, 5TH injector and all wiring to see where the problem is for starting…..
Let me know how you got on I have had two weeks of playin Gand am well versed at the moment on what worked for me and what did not!
Thank you for the comments who took the time to give advice
jim
Good job in getting it running. Always good to have more knowledge on here - especially on the dark arts of K-Jet!
J
Happy to help where I can with my opinion to anyone else having troubles and happy to physically help too in the NE of Scotland!!
Jim
Lucy750Y said
I since added fuel line to separate fuel pump and battery, I also added some wood framing to hold the bottles up and a better return. It done the trick. I bought a pressure gauge from local hydraulic shop with valve so I could check pressures.
Hi,
I was wondering how you balanced the injectors and how you finally got it running!
I have tried new, pumps, accumulator, relays, 3 metering heads, new distributor and new fuse board. Now have one injector with a strong spray (maybe too strong) one not bad but and the others with just a trickle.
Also had a little engine bay fire. Oops. but all ok.
Any info appreciated
thanks
Con
Regional Host NE
plate as if it is not set correct the plunger will
allow fuel to go directly to the injectors just a
thought maybe looking in the wrong direction
