Kjet Fuel Filter leaking
(In Topic #219206)
I am wondering if I am tightening it too much, any idea of toque setting?
I think I might need to replace the copper washers and try again as I imagine I have deformed them now. Any idea of the size?
Any tips? Cheers
If any older than 2 years or 20,000 miles buy a new one and replace the washers, 1 side uses same size as sump plug and the other side is smaller but I can remember the size but depending on which make fuel filter you buy there is 1 smaller washer but get another 1 as it's best to replace both on both sides of the filter.
The fuel system is at high pressure so it's easy to get a fuel leak if system not tip top….
There is 2 types of fuel filter depending on age of the car, early cars up to 84 ish have a smaller filter and from then bigger filters was fitted.
MANN filters sometimes come with a washer but all depends on whether is fell out of the box..
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Ffuel-systems-and_3%2Ffuel-filter-size-help
You can re-use Crush washers, if you re-condition them, I found this out years ago.
Sand them smooth and shiny, (get rid of any Burrs on them with a file or fingernail file.).
Once they are shiny, holding them with a pair of pliers use a Lighter and heat them until they go from shiny to dull or change the color.
You can then re-use them usually without leaking.
(did it on my Diesel for 10-15 years before I replaced them..didn't live near a Dealer). The washers aren't that expensive less than a dollar each, and it doesn't hurt to keep a few on hand.
I also wrapped the threads and threads only of the banjo bolts with PTFE Tape.
