Braided fuel lines
(In Topic #221211)
Skickat från min ONEPLUS A3003 via Tapatalk
2001 Zafira 1.8
2001 Zafira 1.8
Re:
I have emailed them two times bit no answer, do I have to call?LeeO said
Ask them - they are very helpful and know Mk1's
On the drive
Myvalver 89 GTi Grey mk2 16v
Re:
Thanks for that! Whats "cqs sat"? Have not heard of them before.Kenneth Cartwright said
Hi mate you can call them but tends to be busy.. I've got a set from cqs sat on my tintop. Ask for little bit longer than standard so you can route a bit better.
Do you know the lenght (aprox.) and what fittings that I would need?
Sat = fitted on my tin top.
On the drive
Or try Richard masters on Facebook, ( crazyquiffs boss)
On the drive
Braided fuel lines
I would like it to fit the original fittings tank?, in one end and 16v air filter box fuel fittings in the other..
Braided fuel lines
The air box (golf mk2 16v PL)
Im guessing that the preasure line from the fuel pump goes to the threaded port in the first picture and the banjo bolt port is the return line in the second picture?
Original 1.8 mk1 cabrio
The last pictures ar the original fuel lines where the threaded side is from the fuel pump side to engine and the hose connections is return line?
Braided fuel lines
https://volkswagen.7zap.com/en/rdw/golf/go/1989-92/1/133-55050/#25
https://volkswagen.7zap.com/en/rdw/golf+cabriolet/goc/1987-44/2/201-69000/
