Air shroud injectors
(In Topic #224319)
Quick question for curiousitys sake.
1.8 GTi head with air shroud injectors, can you block the air shroud inlet pipe and replace air shroud injectors, with conventional earlier style?
Trying to determine if that will have any effect on how he car idles/ runs.
I seemingly have something not quite right with mine, trying to rule it in or out.
Adam.
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
there is a wealth of info on CIS at Fuel System
Check for air leaks and how old is the fuel and what type of petrol, super or normal unleaded?
Injectors are new, brass/ mercedes type. Whole system is new near enough
Fuel also new, shell's finest 99 vpower. Car has had a long hiatus and has only really just been put back together, hence the obsessive checking/spraying/ vaccum leak looking
I think I've narrowed it down to the throttle body itself, sprayed carb cleaner directly on top of it and there was a rise in rpm .. fortunately I've a spare, I've not messed with!
Once again thanks for the pointers chaps, much appreciated
'83 MK1 Golf GTI
