1.5 carb engine - what is this green thing meant to do!?
So, I recently bought a MK1 golf, first time owning a petrol car and a carb engine. Under the engine bay is this green thing bolted to the bulkhead. It has a single fuel line running from it. Which is apparently connected to nothing??
It goes to a three way split, which runs to a breather and another breather. It's entirely disconnected from the entire engine. What should it do and where should it be connected?
Last edit: by Volks42
vacuum storage unit
nicci21paul said
vacuum storage unit
Where should it be connected to the carb? All the pipes on mine are already on use, I can't see where to connect this object.
Depends on the type of carb fitted. If original it is connected to a Pierberg1B3 carburettor. If an aftermarket Weber is fitted, I belive this item is disconnected and not used.
Sent from my H3113 using Tapatalk
A
