What wires are these? AHU engine 1997 sharan
Im gathering parts and info on  fitting the AHU engine into a cabby Gti I have . Not sure on these wires though
Can't tell you, but from past experience the Brown/White is usually an ancillary ground, as in from the Door Switches to the courtesy light
Wire colors are semi standard, and knowing where they come from and what they are in is a good help.
I would get a Bentley or a Haynes for the model and the engine that you have, then try to match the looms from it to a Cabriolet of the year you are running.
You didn't say which set the wires belong to, from the Donor, or the Cabby?
Sorry the wires are off the sharan
Sharan owners club if there’s one may help,
Or rubjonny
Cheers mate
