Voltage regulator
(In Topic #215796)
I've took the voltage regulator out as I thought I would clean up the connections etc and on removing the regulator I found 1 of the brushes is completly worn down, the regulator is newish and I've only done about 18,000 miles with it in the alternator, any ideas why it's worn down 1 side so quickly?
Voltage regulator
How to change brushes in Bosch alternator regulators. - YouTube
or buy a new one.
If you look wn in to the alternator, you will see the stator or slip rings, make sure that they are even, and clean
Clean them with a pencil eraser…..polish them…
then use a straight pin to clean out between the grooves.
If they are unevenly worn, then you could have it repaired at a good electrical shop, or buy a new replacement….
regulators here cost about 35 bucks usd,
brushes themselves are about 5 bucks usd
whole alternators 95-120Amp are about 100 usd and the 60-65 amp are about 68 bucks usd.
most alternators you buy will be re-manufactured units rather than new. possibly cheap parts were used or it wasnt put together properly
I'll keep and eye on how the bushes wear, the first regular was a Topran one and the one fitted is a Meyle so I'll see what happens…..
