VDO gauges
(In Topic #211680)
I bought a gear stick surround with brand new gauges fitted however first problem is that they have no bulbs or holders can you buy these separate.
Secondly how do you wire them up, the voltage one is simple but please help on the others
Thirdly am I correct in thinking I have volts, oil temp and oil pressure gauges
Sent from my iPad using Tapatalk
VDO gauges
Regards Volkswarren
VDO gauges
For the oil pressure sender, be aware that you need a sender with the correct switch for the oil pressure warning light/buzzer if replacing the existing switch and not using a spare outlet on the block/head. Also the correct range (5 bar or 10 bar) and most on ebay are some weird US thread that is almost the correct metric (M10?) but not quite.
vdo gauage wiring - Bing
Not sure about bulbs but try this site;
http://www.autobulbsdirect.co.uk/standard-dashboard-and-panel-bulbs-for-cars/
VDO gauges
VDO gauges
http://m.ebay.co.uk/itm/181475096855?_mwBanner=1
80 PSI is about 5.5 bar so I guess its about right for a 5 bar gauge. Seems strange they list it as PSI and not bar……. At that price, I'd keep a look out for a cheaper second hand one.
VDO gauges
http://www.ebay.co.uk/itm/Oil-Pressure-5-bar-M10-X-1k-WK-Sender-Unit-replaces-VDO-warning-contact-/371938211859?hash=item56993eb813:g:umkAAMXQVT9S1D3F
VDO gauges
VDO gauges
