KEYS. Lost GOLF MK1 GTI Cabriolet 1988
(In Topic #208599)
Advice needed my keys have been lost
can I get keys made without replacing locks and ignition barrel ……. ????? A any advice or help much appreciated thanks
Paul
If your door locks are the originals, then there may be the key number stamped on it, You also may be able to get the number off the rear hatch lock.
To remove the door handle, you pop the cover off and then remove the 2 Phillips screws that attach the door handle to the door.
If you have separate keys, then you may have to have the ignition switch removal (take the steering wheel and signal levers off to take the lock cylinder upper bearing housing out )to have a key made. But at least you can have your Door locks re-keyed so you have the one key works all again.
I am fortunate to have both Original Key Fobs with key codes for both of my Cabbies so I can have keys punched at the dealer, or my favorite Lock Smith.
It also helps to know which key blank that you need, usually AH or AN.
www.cabby-info.com has a link to how to remove the steering wheel as well as the door locks.
Wes
