Terminal removal tool
(In Topic #217739)
Are these worth while? I'm going to have a bit of wiring to tidy up on the Golf and I'd like to keep it all looking original.
Depending on the type of pin you go back with you may need to either Crimp them, or solder.
https://www.walmart.com/ip/STEELMAN-95978-19-Piece-Master-Terminal-Tool-Kit/16551131?wmlspartner=wlpa&selectedSellerId=0&adid=22222222227016731041&wl0=&wl1=g&wl2=c&wl3=52577926631&wl4=pla-84459807551&wl5=9010814&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=16551131&wl13=&veh=sem
Maurice
'84 GTI Cabriolet (undergoing rework and upgrades)
'83 T25 Caravelle (Daily Driver)
'95 T25 Caravelle/Camper (SA import, awaiting re-commissioning)
'96 Toyota Hilux Surf (Daily Driver)
'73 Beetle Based Trike (project)
as i say most of the plugs are spades so a lot of it can be split down easily with just a pick tool or thin screwdriver. the small round pins on fusebox you need a proper tool, which handily is dirt cheap. I think Mark Carter at classic-vw.co.uk is still selling them drop him a line (they are well worth the money!) for the big round pins these are dead easy again just need a thin screwdriver or pick just lever in the 2 tabs and out they pop.
for the rest it'll be junior/power timer type which are common so plenty of tools available from dirt cheap which need a slight mod to more expensive, to extortionate:
https://clubgti.com/forums/index.php?threads/vw-crimp-connectors-and-tools.192104/
95% of the MK1 pins can be had new cheapy cheap. main ones you cant get are for the clocks and handbrake light plug, so be extra careful with those and if you need to replace its either solder or find another dash loom to retrieve spares from. (these are easy to remove, just lever the flap on the back and they pop out)
