Speedo madness
(In Topic #211986)
Issues with the speedo
An odd one here. So the speedo in my MK1 goes a little mad when i'm doing anything over 30MPH. Just driving down the road up to 30MPH is fine, anything faster than that it read 50MPH plus. While i was doing 60MPH down the A3 it way saying i was doing 100MPH.
So far i have pull out the speedo cable which has been replaced with a new one and i have replaced the drive end too (red end) on the cable too.
Some reading around this is saying that the speedo is broken & i'm looking at a replacement, due to a band ground. Now before i start pulling ground out all over the dash to get the speedo dials out i wanted to see if anyone else had any points?
How-ever I don't know if you have a oxs light on your dash, but depending on the year your cable could go into a counter box, then out of the counter box to the speedo.
If you have a one piece cable to the back of the speedo, then it is the speedo.
If you have the counter box, then you might want to get a one-piece cable out of a "Cabriolet of the 90's" or Diesel's and take that out of the loop.
It sounds as if your return spring is broken, or is slipping and giving the needle a boost.
Speedo madness
The car is 1986 mk1 Cabriolet 1.8 GTi
I don't think it's got a box unless this makes up the speedo..
Does this help firm things up what it might be ??
