S1 1.6 Carb to DX injection wiring
(In Topic #219554)
According to other posts, it's possible to adapt a DX engine loom to fit the S1 bullet style fusebox I have, but is this the easiest way? How big of a job is it really? Or am I better off finding a late mk1 fusebox and adapt the dashloom etc to fit? Any input would be helpful. Thanks
Last edit: by goldie_88
Early 77 year model Golf. 4-Door
to convert the dx loom to original fusebx isnt tooo bad, as tbh the kjet wiring is all separate from the fusebox anyway, and you'll want to mount the fuel relay above the fusebox too since when fitted to the fusebox it tends to burn out the pump power pin.
you may need to rewire the coil power, if your old points ignition coil power wire is purple/white that wont work on the new DX coil
I do have points with a resistor wire to the coil originally. Is it just a matter of running a fresh normal wire in place of the resistor wire?
Also, would you know if the relay in the photo is the rev limiting type, or do I need the rev limiting rotor?
Thank you
with the fuel relay ceramic fusebox dont have a limiter in instead its on the rotor arm. if you want a relay with a limiter go for a later CE1 type, and use a fuse inline. If you find VW fuse & relay holders they clip on top of the ceramic fusebox. Those again are available from VW or pinch from scrappy, I always have a decent supply of them for my loom builds
