Replacement heater / blower
(In Topic #215893)
If not, does anyone know where I can source a good quality new one that is right for my car?
Thanks in advance
Dan
If you let us know which car you have then the collective wisdom will work better!
johnprogers said
Hi Dan,
Yep, that would help - it's a MK1 GTI Cabriolet "F" Reg (1.8 8V).
johnprogers said
Yes it should work. 251819015 is the same part code as the blower I put in my 1991 Clipper back in the spring.
Thanks. I've ordered and will give it a go.
Re:
Thanks for the tip, I managed to brute force the old one out, so should be able to do the reverse to refit!johnprogers said
There is a fitting guide on here that suggests splitting the fan in two in order to get it in, but I found I could wrangle it in place without, so I avoided the issue of putting it back together after splitting.
Sent from my Lenovo P2a42 using Tapatalk
I had to do that to 2 of my 3 Cabriolets.
Briano1234 said
I would also suggest that you check the cabin side of the heater fan connector as the brown ground wire got toasty and I had to splice a new wire to ground from the engine side of the cable to insulated male female connectors to frame ground.
Thanks, I'll check that out, too.
