no dash lights
(In Topic #220325)
If all the other lights work with the switch as far as other gauges, and or the radio, then it isn't the switch but the cluster itself.
If you haven't replaced the bulbs, then go for the bulbs, but check the fuses first.
On the cluster itself you probably need to add a new Ground point as well as plump the connections. See:
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Funtitled_236&start=20#post_1613249
thanks
I would also say that on the cluster gauges there is the ability to pull back the mylar, then remove the light housing. If you then take that apart you can get to the Green film that gets really cloudy, you can take that out and using 3000 grit to clean the cloudy off, then use a wax to make it clear again, or you can just leave it off.
Replace and affix with 5 minute epoxy, and then when set carefully replace the mylar and insert the new bulbs.
Last edit: by Briano1234
Get some fuel in the car, not a good idea to go to low incase you start to suck up the old cr*p in the tank. Not a problem if it's nice and clean in there.
