Mk3 wiper motor problems (again)
(In Topic #212741)
I have hot wired the motor from the battery to check it works on both speeds. I have checked continuity of wiring from stalk to fuse box and from fuse box to motor plug and all is ok. I have tried several different '18' relays and '99' relays.
I'm using the multiplug from the mk3 golf with wiring connected to the original wiring matching the colours. Is this correct, I'm assuming the colours will be standard across the vw range?
I have 12V on the black/grey wire at all times. In slow wipe I also have 12V on the green wire. Fast wipe I have 12V on the green/yellow wire. On intermittent I have 12V on green and green/black wire. From looking at wiring diagrams this doesn't seem right, on slow wipe should I have 12V on the green/black rather than the green? Can anyone clarify the function of each wire colour?
Thanks for help, at the moment it looks like a problem with the fuse box or the stalk.
(Note that I swapped out the original motor as it only worked on fast speed - even when hot wired from the battery, it still didn't work on the slow speed.)
You might need the #99 relay programmable from the mk3.
So, I swapped round the green and the green/black wires in the wiper motor multiplug and it's all working perfectly
