Mk1 horn help please
(In Topic #217026)
I've found the wire from the head lights black and yellow and that is live when I put the he ignition on, I've had a look at the steering wheel and the plate on steering wheel is not live or anything how does it all link together ?
All my other lights and everything else is working so I'm a bit confused, I've purchased twin horns and they are ready just wondered how it all linked to the steering wheel and why is the wire in the engine bay always live when the ignition is on and not linked to button on the steering wheel if that makes sense
Thanks guys
When looking at the horn remember VW wired them differently from the rest of the automotive world. Most are earthed to the chassis where they are fixed and pushing the horn connects +ve 12v.
With VWs of this age they are feed with +12v when ignition on and pushing the horn on the wheel connects to earth.
Sometimes there is a bad connection at the steering wheel, there is also a earth wire that connects the steering column/rack to the bulkhead. Unfortunately this located is in the engine bay quite low down and gets corroded and drops off.
If twin horns (and single?) there is a relay in the circuit too. As the wiring ages and resistance builds up not enough power gets to the horns to make them sound. A quick fix is to disconnect one horn leaving enough juice to power the single remaining horn.
Thanks again
From there it travels up to the (turn Signal switch Wiper finger) to meet with the back side of the steering wheel)…..
here is a simplified diagram.
