MFA
(In Topic #215757)
Which bit? The stalks or the brain bit?
(Moved you topic to here as you're probably going to get some better help here mate)
Ian
ah, thank you 😊 I'm looking for the screen and the brain i think as mines blank 🤔borednow said
Banshee101
Ian
mk2 clocks can be fitted but you need to mod the dash brackets and splice the plugs on
rubjonny said
if its blank might be the fuse has gone.
Bit embarrassing if it's only the fuse 😳 I'd better check it 😂. Do you mean the entire clock set or just the MFA clock can be swapped out from mk2?
it could be you have lost the earth as well, look for any broken/dirty brown/white wires to the side of the head
rubjonny said
the whole clock set. the internals are all very different I'm afraid
Ah, that'll no be an option for me then must retain mk1 clocks……..I shall try the fuse and broken wires thank you 👌
