Idle Control Unit Relay
(In Topic #220065)
mine is this:
So now for the question: Is that 43 relay in the correct spot? Is it the correct one? Thanks!
Last edit: by Mobys
If you notice on the fuse box relay diagram it's for USA cars, we don't have the seat belt warning or air con relay in the UK cars.
Have a look at this thread for UK cars.
View topic: Fuze box wiring layout . Relay locations . Fuze locations . - The Mk1 Golf Owners Club
The Early mk1's from about late 79-84 are the ones that are "Westy" or "Merican".
Cabriolets we all made by the Karmann Coach Works in Germany and then exported over here to the USA.
The top of the fuse panel is layer 3 or floating relays, that is that any that add-on to the original fuse panel can be in any of those optional slots.
By a simple re-wire of the side markers you can have side repeaters that flash in opposite to the turn.
High Tail or not no-one ever sees it prior to impact, at least the 3 times I have been rear-ended.
I don't know how many cars have those and or other brakes lights out…. For many of the other issues I blame California.
