help me fit a manual dash switch for my radiator fan
(In Topic #211696)
cant remember what i need and not done it on a golf before.
1.3 driver GF engine 1983
want to install a rocker switch under steering column / dash area.
so i can manually switch on the fan if and when i want but still have it function with the car thermo switch.
wheres the best place to splice/run the wires?
cheers guys
i pressed the little red button
best way is to mount a relay to handle it, and trigger that from your switch. that way you dont need a high amp switch to take the load
but there realy is no need, just make sure all the parts work properly with good quality parts and leave it as VW intended
The only thing I know for sure is that the Wires are colored on the 70 Golf to the blower motor that carried over to the 90's… but the other side of the motor connector is totally different…. ARGHHHHHHHHHHHHHHH.
