Fuse board max draw.
(In Topic #208863)
I am looking at the wiring for my car now and am planning on running a battery in the boot.
I have a mega fuse box front and rear. A double in the front that will feed the main fuse box. I was wanting to fuse it with a mega fuse. Has anyone any ideas as to the total current draw for the fuse board?
TIA
Craig
I don't recall the Fusible Link Rating from the battery to the fuse panel but I would suspect that 40A is about what it is set at, that would be 10% above the max rated fuse. And is another good reason to relay high current draws off the ignition and head light switch.
The headlights will be on uprated looms.
I have 300amp rated cable and was going to fuse the cable at 250amps each end.
I work that out to be good for the 1.8t starter.
Craig
