Faulty high beam
(In Topic #209722)
Currrnt problem is high beam.
It's there and it works (got a feeling the loom has been updated) but it won't stay on.
Tried a new switch but still getting the same problem.
Thinking it could be the stalk?
Cheers in advance
Problem are the two smaller wires on the back - black yellow and earth. They're loose.
Looks like a need a new connector as it doesn't come apart
pics? they shoudl always have a connector, or at least spades. if its been soldered on direct captain bodger has been in there before you…
Remember what "Smokey the Bear" says, "Only you can prevent Electrical fires…. "
Smokey was a bear cub found after a forest fire over here on this side of the pond, and he was used as a spokesbear for Fire Prevention.
rubjonny said
the 2 thin black/yellow and brown are for the wee illumination bulb, probably gone missing over the years is all
Definately the bulb wires. It's blown, would that be the cause?
Captain bridge has definately been there, there's a couple of pics on my build thread but I thought I'd sorted it.
Clearly not.
Taken the lot off to clean it all up.
let us know how you get on fixing it up!
Works a treat.
Thanks for the help
