Ever-dimming dash lights
(In Topic #208462)
I've never taken the instrument panel to pieces - is it easy? what kind of replacement bulbs would I need? Tell me everything please! Ta
Written by my own fair hand too!
It's easy, just be methodical. Removing the steering wheel gives more access but isn't essential from memory.
It could also be your headlight switch with the dimmer that's the culprit.
I tossed the Green film that was cloudy. I also used the lamps out of a Saturn Honda, as the lamp sockets were plugable. On going back I looked up the warning lamp numbers for the same car as in Honda/Saturn/Isuzu as the warning lamps are higher wattage, and gives more illumination to the cluster.
sylvania 161
I wiggle mine every couple of months as it's the sort of thing you just don't adjust once set.
You can just see the contacts which the dirt and dust sits in.
http://www.ebay.co.uk/itm/VW-Golf-MK1-Headlamp-Headlight-Switch-1979-1983-INCL-GTI-/182203375339?fits=Model%3AGolf&hash=item2a6c2adeeb:g:6P8AAMXQTT9RsLsc
Now a really dumb question - can I get the bulbs anywhere, or are they special ones?
