Carb to Injection
(In Topic #212681)
What’s left to do before turning the key - can someone advise if the below is correct please:
Connect main fuel pump positive to E14? Negative to spare brass plug above fusebox?
Run a wire from main fuel pump positive to lifter pump?
Fuel pump relay (67/80/167) into socket 2?
Might still make it to Harwood House in a fortnight with some pixie dust lol.
for e/14 to work you need to run the 20v ecu trigger purple/white wire to D/13, and use a 67, 80 or 167 relay in slot 2.
spade N is used for injector power on later digi, you could use it as well if you wanted. or you could power the pump from it with an inline fuse. (or both)
Perhaps the fuel pump relay is built into the loom already which is what could be throwing me. There is a relay numbered 61 built into the loom but thought this was for the ecu?
what type of ecu is it, dbw or dbc?
