Anyone know what this wire is for near Carb
(In Topic #212719)
Wiring
the other is ignition live, its possibly for the carb heater which is near the bottom of the carb on the front. it should have a wire pokin out with a spade on
you have 2 electric valves round the back, they should both have ignition live check the lower one has a plug on it
rubjonny said
the one on the front of the carb is the thermoswitcvh for the radiator fan after-run, as I say if the black cut wire is actually a brown wire with a black cover then this goes here
hello the black wire is a solid black wire. Its connected to a bit on the carn it looks like a bolt, possibly some kind of sensor? the wire was hanging on by a few threads but i pilled it and it just ripped off.
the other cable is black with a yellow line down it.
The second wire the black with yellow down it is ignition live?
yes the black/yellow is ignition live
rubjonny said
I'm sure EZ_pete on clubgti managed to repair one, see how you go.
sorry im not sure if you answered this question but where does this ignition live connect to?
rubjonny said
is there anything connected to the autochoke?
Which part is the autochoke? The 3 point unit?
