6 speaker wiring
(In Topic #222743)
Are these the original speakers?
If the LH and HF units both have their own cables, where are the crossovers?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I haven't had time to look into all the wiring for the stereo. The head unit is non-standard and the manual only lists it as having FL, FR, RL, RR. The connector has crimping connectors on it so it is hard to know what was there before. The cab is a Classic Line, so I guess it had a reasonably high-spec system.
I think of "active" as a speaker having it's own amplification built-in.
I have an "aktiv" Hi-Fi system. Each power amplifier is preceded by a line level crossover designed specifically for the unit being amplified. So the each of the six power amps is only amplifying the frequency range of the driver it is connected to.
So what is "aktiv" in terms of car stereos?
EDIT
I just read the aktiv guide. I'll check to see if it done like that tomorrow.
Last edit: by the_whip
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Check the link I showed you above at cabby-info, she has both the acktiv and the non active 6 speaker wiring.
You can also look here, not as colorful as Kammy's
Cabriolet:
Radio wiring
85-89
Red 12v+ large Unswitched power need for memory B+
Brown large main frame ground
gry/blue dash light
lf spk
brn/red -
brn/gn +
rf spk
brown -
br/red +
lr spk
brown -
blue +
rr spk
brown -
red +
You will need to get Switched power from Defroster switch black/yellow
Radio2 85-89
Red Large 12V+ unswitched power for memory b+
Brown large frame ground
grey/blue dash light
lf spk
brn -
brn/blu +
rf spk
red +
brn/white -
lr spk
br/r -
blu/green +
rr spk
red/green +
br/black -
1990
lf spk
brn/blue
blue
rf spk
red
brn/white
lr spk
br/red
blk/green
rr spk
red/green
brn/black
1991-93 six speaker passive tweeter high in door
t8pin 7 red large 12v+ unswitched
t8pin 4 Brown/red 12v+ switched
t8pin 8 red large gnd
t8pin 6 grey/blue Dash light
Brown/red large 12v+ switched
lf spk
brn/blu -
blu +
rf spk
red +
brn/white -
lr spk
brn/red -
green/blue +
rr spk
red/green -
brn/black +
1992-93 Active Amplified 6 speakers.
Speaker amplifier
The Bass speakers are wired from the amplifiers, and there is no color matching on them.
Left
brown/black t6/1 Tweater gnd
Red t6/2 Tweater +
brown/red t6/3 Midrange left gnd
blue/green t6/4 Midrange left +
red/gray t6/5 Power from f3
brown t6/6 ground
t4f/1 blue/brown to t10/9 radio
t4f/2 green to t10/10 radio
t4f/3 white/blue to t8/3 radio
t4f/4 red/black to t10/5 radio
Right
t4e/1 blue/brown to blue/red t10/7 radio
t4e/2 green to blue at t10/8 radio
t4e/3 white/blue to t8/3 radio
t4e/4 red/black to t10/5 radio
brown/black t6a/1 tweeter -
red t6a/2 tweeter +
brown/red to brown/black t6a/3 Mid Range -
blue/green to red/green t6a/4 Mid range +
red/gray t6a/5 Power from f3
brown t6a/6 ground
RADIO
t8/1 White/Yellow Speed Sensor g54 (cluster)
t8/2 empty
t8/3 white/blue
t8/4 Brown/red 12+ switched
t8/5 empty
t8/6 Gray/Blue Panel Instrument Light +12
t8/7 RED 12+ unswitched
t8/8 Brown Ground
t10/1 empty
t10/2 empty
t10/3 white/blue
t10/4 empty
t10/5 red/black
t10/6 empty
t10/7 blue/red
t10/8 blue
t10/9 blue/brown
t10/10 green
Tips
Large diameter wires are usually grnds or powers
small diameter wires are speaker
To test speaker pairs take the color designated
and touch to a 9Vdc battery you should hear a scratching or popping
