Rusted studs in rear arch - what are they for?
(In Topic #215769)
Picking up where i left off on a restoration of a mk1 rivage, about 9 years ago!
I was cleaning out the arches to check for rust (none found, which is great!), but i have come across what looks to be a stud? this is rusty (same on both sides).
Does anyone know what it is supposed to be for? (top left on inner arch pic)
Thanks!
VW Golf Mk1 Cabriolet - Rivage In-Build. Again.
Sent from my Nexus 7 using Tapatalk
If you can weld its an easy enough fix, tbh you could probably bond a stud in from behind even. Or at least for a slightly neater look inside the boot put a self taping screw in from the back, and put a nut on the outside. Worst case just need a helper to hold the self-tapper inside the boot while you do up the nut
Thanks for the help!
