Removing rear wiper/washer solution?
(In Topic #216219)
Quite fancy the look without the gear there but don't want to get involved in patching and spraying.
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Then you could also try to find a non-washered boot lid and have sprayed to match….
OEM non-sprayer look depending on wallet, shaving and filling then respray is best. If you are removing, then want a true OEM, you will need to find the interior bits as well so you can't ever tell it was installed there in the First place. My Two pence.
Pipe end caps - Google Search
My mk1 luckily has no rear wiper as standard, one less hassle, I hate rear wipers.
Pete M said
Maybe enlarge the hole with a cone cutter until it's round enough to take a grommet!?
A round drill bit with a Drill stop so you don't cut through to the inside
I have never had good luck with a Stepped drill bit.
Nothing a sticker can't sort out for the short term!
