Rear boot won't lock as if kit doesn't fit?
(In Topic #233085)
recently bought my golf and first job was the boot wouldn’t latch. I’ve fixed that and lined up the mech but the key I’ve got won’t lock it. I just insert the key and it’s a bit like a stick in a bucket but won’t turn, any pointers or do I just strip it?
you can recode the lock if you have the tumblers… or try a new lock set from the web.
On the drive
Myvalver 89 GTi Grey mk2 16v
Kenneth Cartwright said
maybe the lock is wrong? did the key work before…?
I don't think it worked before, sorry I'm new to the mk1, what's the tumblers and would a new lock set be just for the boot?
Or buy set above change the easy 1s leaving ignition as found.. since its a bit more involved.
2 doors and boot..
Just means you have 2 keys then.. lol.
On the drive
https://www.classic-vw.co.uk/mk1-golf-tintop-full-lock-set-4882-p.asp tumblers / plates whatever there called ,is how to code each lock to a key..
2 doors and boot..
Thanks looks like another useful site.
Place the ignition key in the lock barrel and see if all the pins go flat when you insert the key. The wafers that don't are the ones that you need to swap out.
http://cabby-info.com/Files/RepairingDoorLocks.pdf
Briano1234 said
If your doors and ignition work with one key, then remove the rear lock, and re-key it to match the ignition key.
Thank you thats brilliant
It now works and I can lock the boot which is a result!
