Headliner
Refit needed with britax sunroof
Any help please! 1984 gti tin top with Britax pop up sunroof.
I do not have the headliner, so I want to put one in:
1. is a job for a professional or can a novice do it?
2. will a sunroof headliner fit a britax sunroof?
Thanks again!
R8J VW🥇
There's a good video on youtube covering the install. Search Edd China Garage Revival. It doesn't cover your sunroof issue though.
See my videos, Tom AFH
Thanks mate.
that will be a great help
R8J VW🥇
If your sunroof isn't an OEM bit you're likely better off getting a standard headliner and removing and refitting the sunroof.
I just started mine, I don't think it's a task out of reach but it's going to take me some time to get it in right. I've got a heap of paper clamps to help get the fit up just right. The spray adhesive I have isn't very forgiving so it has to be right the first time.
Headliner
You’ll need high temperature contact glue and use it out of a tin.
Spraying it you’ll have little control as where the glue goes.
Some glues won’t stand the heat and you don’t want the headliner flopping down.
