Golf Mk1 Cabriolet Top of rear wing repair panel needed
I need a new hood for my Golf Mk1 Cabriolet.
Before I have this done - I need to repair some bubbling on the rear wing where the hood fastens to the car - drivers side.  Where the vertical section changes into horizontal - small strip of almost flat body.
I have searched and unable to source a repair panel for this part - does anyone know if they exist and if there is a stockist in the UK.
Many thanks
Chortle may know of where to source a replacement for that.
I believe it is called the u-channel 155813927
That looks like it - many thanks!!!!!
forward me a picture of what you needing
Yes mine has gone in a similar position. Will take a picture and update. Thanks
mark the area what you want in photo editor mate
Looks like it's gone across the rear and passenger side. Not sure what I need to be honest
It's also gone on the same panel on the rear
where are you located mate
A long way from you :( Hertfordshire
nicci21paul said
Hi Paul Assume that this will be a cut out - which I will need.  How much are we talking including shipping?
how far from birmingham ?
i am using the ones i have on the white car off the blue one mate
Last edit: by nicci21paul
VW stopped producing the Rear cable channel section a long time ago.
When we get a car in for a new hood we end up at time’s sending it to the bodyshop.
So he makes up new sections welds it all up, paints and we do the hood fitting.
It can be worse once the hood is removed and there’s fixing points for the hood behind there needed for the proper fitting of a hood.
