Felt/wool type underlay or not?
(In Topic #216259)
Any thoughts, I think the carpet will fix/it better without but it would help with the additional sound deadening and feel nicer under foot.
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Maybe go down the road of a high quality felt or if you're not in a rush, keep this post active because I seem to remember that there's more modern thinner materials that can do the job even better.
I'm sure we have members that when they see this post they can offer you more concrete advice (sorry for pun).
Sent from my Smartphone
http://clubgti.com/showthread.php?85893-Royal-Blue-MK2-GTI-16v-KR-then-ABF-now-abf-management-widetrack&p=2282043&viewfull=1#post2282043
moderate trim, thin padding and thin carpet. Higher trim was thicker padding, and thicker pile carpet.
The Foam Padding that they are using for Home Carpet works well, is sound deadening, and insulating.. It holds up well, and they make the stuff to be mildew proof as well.
I have seen some of the AfterMarket carpets molded and padded as a kit. So I suspect it all depends on how your replacement carpet is equipped. The Padding also lengthens the life of your carpet as it is a cushion to the backing of the carpet….
