Drivers Seat Belt
my drivers seat belt had an advisory on my last mot, (see image for slight fray)
any recommendations where to buy this style i cant find any?
Well there are companies out there that re-do webbing, but that is Nylon weave belt, you can remove the fray, and lightly hit with a heat gun, or lighter to make it again self seal (nylon melts)… and a frayed edge isn't as bad as your MOT tester wants to admit to……
like: Classic Volkswagen Rabbit Seat Belts | SeatbeltPlanet
That's just a little bit of fraying, sharp pair of scissors and carefully trim the fray bits off.
Drivers Seat Belt
Ok, thanks for the info, I'll give it ago and see if it's picked up again.
Sent from my Pixel 3 using Tapatalk
Did you take the car for it's MOT to a garage you always use or a place offering a cheap MOT like a tyre fitters?
Drivers Seat Belt
Garage is the engine builders. Used since restoration. This was it's MOT last year, they passed it with advisory. Said would probably need replacing next year.
This year I was going to go to a garage closer due to covid, but unsure how I feel about the car being sprayed with anti-bac when I don't know the effect on the paintwork.
They are or should only spray the insides where they touched....
