Door lock pins
(In Topic #215608)
Otherwise it'll mean butchering a load of old door locks 😄
~Madferret
Mk1 1457cc 5door GX '83
They seem to be even more in the US https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/tumbler-plates-and-springs-1-set/443898041a/
~Madferret
They have a large selection of Mk1 parts and you'll find part of the website is in English.
There are a good bunch and do post to the UK. 👍🏼
Sent from my Smartphone 📱
Smig1003 said
You can still get the kit from VW, but it's about £8O.
Go to a breaker and get the door handles off a variety of Golfs, GTI's Cabriolets, jettas you can also get the pins or wafers out of the trunk locks which is way easier to remove the pins and springs, which is what I did to get an assortment of pins to rekey my mismatched lock sets….. I left the ignition key alone and matched it to the handles and rear hatch as it had 4 keys, and all were different save for the OEM ignition key with the key fob numbers. Yep Drivers door different from trunk, passenger door different from drivers and ignition, and only the ignition and glove box locked with the same key….
www.cabby-info.com has a link to a how to on re-keying your locks. I don't think that a locksmith would cost you that much to re-key if you take out the lock cylinders which is easy to do.
Some call them pins, some call them wafers and some call them tumblers…..
There are only about 4-5 different ones made,
~Madferret
Won't be too much of a bother once I've got the central locking working again (just a bad wire).
Thanks for the help 👍🏻
~Madferret
Probably only one or two.
The ones that don't fully retract with the key in can be filed smooth to the lock barrel and your issue will go away.
