DOOR GLASS STUCK IN DOOR
If anyone can point me into how i can access the glass that has fallen off the rails and now sits inside the door. Is there a photo tutorial someone can point me too please.
Depends which door.. front or rear.. front first try removing door puller,door puller lever ( screw under winder cover pop it off) 2 screws in door handle then lift  twist the  handle upwards until comes loose, pull door cards off/ lever off.  if motor or manual winders,by undoing the nuts on door, that should give room to manoeuvre to refit in guides
Rear is similar remove window winders any over lapping trim covers and pull.
On the drive
Myvalver 89 GTi Grey mk2 16v
Be aware that the metal rail/clamp that holds the window can rot allowing the window to drop in the door. I've had this and also had it where it had just popped out of the rail/clamp (its wedged in with a strip of rubber)
If its rotted you'll need to get a replacment before you can fix it.
See at the bottom of the glass in the link;
Volkswagen Golf Mk1 Front Door Repair - Workshop Manuals
This should be a link to the door trim removal. Its prob better long term to get the correct Haynes book of lies if you are wanting to DIY
https://workshop-manuals.com/volkswagen/golf-mk1/images/golf-mk1-226.png
Always nice to know the year, and model, tin-top or Cabriolet, as well as front or rear, and manual or electric.
Hi yes sorry i'm new to this. Its a 83 Tin top 5 door GL Model. Its the front glass manual mechanism. I have removed the door card and found the glass had come out of the slider. I have tried to fit it back in but only one side seems to snuggly fit back into the slider. It works but am not convinced how secure it is. The problem occurred when i closed the door with the window down. So i wont be doing that again. I am now going to give it a good clean and oil 20200506_152957.jpg
Fit a thin piece of rubber mat,foam between the gall and hold/clip. Or a run of silicon to hold it in place .. I cant remember if the 2 bolts add a bit of tension to the glass also..
Dont worry.. people here to help…best they can with limited info.. most things can be fixed…
On the drive
Its popped out of the rail/channel/clamp, maybe becuase its lost its grip by being corroded?
When mine did it I removed the glass and channel (undo the two bolts) and gingerly tapped it back on with a rubber mallet.
As above if its gone missing use a fresh piece of rubber mat or foam
