C-post corner piece fitting- cabrio
(In Topic #215133)
got my new C post corner seal and noticed that it has a littel tail that mine didnt had….
can i fit it without taking the roof down?!
On the drive
Myvalver 89 GTi Grey mk2 16v
Slacken the rear cable, then you need to get a tad bit of slack between the top(hood) and the body.
It is a somewhat medium task.
When re-tightening the rear cable take care. I would suggest marking the bolt with a sharpie so you can return it to the same place.
as if you get it too tight you chance snapping it.
lets take it easy- the roof is the only part in my car i've never touched before.
where is the cable?
pictures will help me a lot!
thanks evreybody!
Where the cable enters the car.
CAble being inserted in tray.
what you wil see folding the top back.
You may have to Drill the rivet and peal the top carefully back.
Also you would do better to half open the top and use a safety to hold it there.
Holding the top cable with a long pair of hemostats while using a 10, or 11mm Articulating speed wrench
pigtail seal outlined.
