1988 cabriolet interior
(In Topic #225250)
Trying to find interior code
The First number is your Paint LA8Y the second is the Interior CN as it was originally.
From Cabby-info.
Beige….? But it never mentioned a recaro, only sport seats…. So yours may have been re-done.
Life Member
Life Member
The above images are the same in the brochures 10/87 and 7/88. Below are images from the 8/89 brochure. It depends on what month you car was registered I suppose as to where it would fall in the brochure print
That's great, so mines the bronze grey metallic, beige roof, and beige tartan, guess I'm just going to have to go with the cloth I've already got as on the picture as that's the closest match. Will have to give the other seats a good scrub to see if they lighten up like the drivers then haha! Also I've just fitted a Weber carb (2nd hand) I've used a service kit and changed the mounting gasket. has anybody got a link for how to set the idle revs. At the minute it's just cutting out straight away which I guess is to with some of the existing tubes to the old pierburg they need blocking off/removing. Cheers
Briano1234 said
Well from Cabby-info.com we find.
I think somebody told me previous someone has added the recaro badges themselves.. done a very good job! Thanks for info 👍🏼
