Water oil cooler delete
(In Topic #220136)
1.8t oil cooler delete
To get the pipe thread out, you put the nut on and spin it so you can clamp the nut and the inside of the pipe, then clamp a Pair of Vice Grips on it to spin the pipe out.
You will replace the "t" hose with the cheaper version that connects from the WP to the BY-Pass metal, then get a rubber cap to seal off the water outlet flange fitting.
The Thread pitch is the same on both ends, and it is about 2-2 1/2 inches long. Called a Pipe Union.
You screw the new one in until it stops, I use Teflon tape on the threads in to the filter flange.
If it Sticks out too long no worries as the filter is rather hollow, and will take the extra length. You just have to spin the new filter off a little longer… . I had that issue when I converted my 90's to external oil cooler, as it didn't have any oil cooler on it.
Great help much appreciated.
